Hello,
This is my new subject. I will try to convert this army helicopter (on skids) on a navy version (on wheels).
I do not know so much Westland Lynx helicopters, but I think Aéronavale Lynxes are Mk IV...
Here is the gift I received from my wife for 2 years:
Inside:
There will be a lot of work
I do not know how to tackle this resin, it's not a resin for improving models, but resin to impove
I wonder if I can save the nice sound proofing ?
Some broken parts here
The rivets are realy awfull, Archer will make a lot of money with me I think
So, let's start
Norbert
Comments
Sounds like a fun project to
Navy Lynx
Hi There
Great to see another Lynx fan on the group, I am working on a navy Lynx from Belcher Bits. I am Lynx mad and have only last week found the company Accurate Amour that make the model you have. I called them to find out if they do the navy one but they have no plans to make one.
I have lots of information, details, picutures of the navy Lynx as my farther used to work on them.
If I can help in any way I would like to help.
Thank you Oliver, Thank you Justin
Thank you Oliver, Thank you Justin.
Justin, I saw your build starting. I too have plenty of pics of french navy lynx that I can share with you.
But if you can help me, I'm looking for picture of how it is under the mesh of the turbine intake.
I have to change that in 1/35
Norbert
intake picture
Hi Norbert
Updated the pictures of my Lynx it's starting to come together now.Lots of filler and sanding.
Here is a picture of the intake you wanted,I will try and find a real photo of it.May I ask why you need it most Has 2 and Has 3 all had the metal mesh fitted.
http://www.belcherbits.com/im
Take a look at these as I thought you will have to change the nose too.
Thank you Justin
Thank you Justin
in fact, the metal mesh looks like this one :
and in 1/35 scale, i have to get the feeling of the depth behind the mesh. On the real machine, I didn't see the turbine intake, but I think I have to get the panel shape that we see behind the mesh. I wouldn't do it in 1/48
However, the shot of your kit part gives me a better idea of the lines.
Yes, I will have to madify the nose.
Thank you for your help
Norbert
thanks
No Problem glad I can help out.
Just got text from a pilot friend should be going to see my dads old lynx in the coming weeks.I will email pics to you.
a try to compare with the real one
I've shot the model with a 200 mm camera at about 4 meters (about 13 fts).
So I will compare with the real one:
Top
Bottom
different areas
The roof on the front thanks to high def pictures.
Maybe I did not shoot the Lynx from far enough, but it is the best picture I have.
Apart of the too long rear fuselage, the not enougth bulbous turbine housing, the too high roof, the angle of.... The model is not that bad
So here it was
Norbert
lynx update
So I started by the roof.
So I started by the roof. yes it's unusual, maybe I build upside down.
Here is the inside of the roof, with the door rails on the side
I started to prepare the turbine floor, from the back of the helicopter
The floor is flat, then goes upside, I mean following the panel line
Then you see the roof who will be also the main transmission floor. It lays on the rails, all shape have to be done yet
and then I will work on the cockpit roof
Lot to do now, It will take a long time to build
Norbert
lynx
well done on starting the lynx it may take some time but the best things come to those that wait.
I am still working on mine will up load some pics soon to show you my progress,the tail has been removed and fitted four time now but it must be right.
I take some time trying to
I take some time trying to thermoform a new roof.
I had some surprises
some disapointment
So I resumed trying to use clear plastic, I surrely didn't take the right material : back to white polystirene
So I could make some progress
I'll go 3 weeks in Australia in February, then 2 weeks in USA beginning March, so no big update next time...
Norbert
Norbert
Hi Norbert, THE KEY TO
Hi Norbert,
THE KEY TO SCRATCHBUILDING IS THE WILLINGESS TO DO IT OVER AND OVER.
Your Lynx is coming along just fine. Nice work,
Oliver
well done
Norbert keep up the hard work,I have had blood and tears over mine it will be worth it when it has finished.Keep the molds your making I may need some parts in the future.!!!
Hi, I'm back with some
Hi, I'm back with some updates
I worked on the turbine housing form :
I tested how to reproduce soundproofing
And I started to build the sponsons
Allignement is tricky, in fact I had to allign on the floor as I had a surprise with a difference in shape between the left and the right sides of the fuselage.
So it start to look like a navy Lynx. still a lot to do. I hope you enjoy the pictures
Norbert
Norbert
Accurate ARmour Lynx
Hi Norbert,
that looks like a lot of work for such a "cheap" resin kit
Keep up the work, love to see it finished
Tim
Hi Tim I just could not
Hi Tim
I just could not build this "cheap" model out of the box.
I went further with the sponsons :
there will be a need of tons of putty, due to the high difference between the 2 sides
but I'm on the good way, I have just to push down on the bad boy head
Norbert
Norbert
Hello, here are some updates
Hello, here are some updates :
I go forward on the turbine pannels :
and I'm still working on the sponsons :
It is now slowly time to begin the interior, I started by new soundproofings, I was not happy with the originals :
I prefered to have real losanges
Now the roof, and a lot of other things
Norbert
Norbert
very well done
Hi There
Not been on here much work keeping me away from the pc.
Very well done on the model,it is realy starting to shape up.
Keep up the good work can't wait to see it finished.What year/ model are you doind HAS 3 Etc
Thank you Justin here
Thank you Justin
here some small updates :
Sponsons shape is done :
I changed the roof windows shape
Prepared the new nose
Norbert
I also made a new
I also made a new floor
modified the bottom shape
and made a new fin air intake
still a long way to the finnished model
Norbert
Norbert
Amazing work my friend.
update
Very well done you are a master can't wait to see it finished,keep up the good work.
long time I didn't update
long time I didn't update :
I did a new transmission box
I added thingies under the fuselage
I scratched a seat
I scratched the submarine hunter desk
and I'm currently working on the sonar hoist
that will be half hidden inside
Norbert
Norbert
Nice work!
waaw, those are very fine details you are adding! Nice work
Extreme cool work
That is awesome, u know what u are doing !
But i would have buyed the version i want to build, hehe
Helicopters have ruled warfare and SAR since it was invented !
